Temp and fuel gauges 2.0
Rescuejeff
- Greater San Diego Area
- 1983 CJ7 Laredo, 258 inline 6 with stock everything else. Have a Dana 300 trans with and Dana 30 front axel and AMC 20 wide trac rear end with a T-5 tranny.
Did the nutter bypass and took off the cat.
SO went through everything to get good grounds and such...replaced the temp sender, and fuel sender and well...50%. Fuel gauge now works but the temp is still acting weird. Be honest I'm puzzled.
The gauge started to work then pegged hot and dropped back to cold. I touched the wire and it's hot as hell on the sender...and the gauge stops putting out power. Take the wire off the sender and then I got power again. I wrapped the sender in Teflon tape to help with grounding issues... Any ideas out there??? Thanks!
