Build Thread The $120 Jeep CJ7 build thread
They had a magazine with that car in it at the shop where I got my stuff.
Ok - I’m just gonna say it. Your work area just plain sucks. It’s too small and cramped. Your floor is much too open, and the overhead clearance ain’t right - you need a bunch of :dung: hanging in your way. Oh, and it’s was too bright in there. Take some bulbs out. Gert and I will be more than happy to come out there and show you the proper way to clutter, I mean set up, a shop.
It’s a good thing I don’t have that much room - I’d have a couple Jeeps disassembled in there......
Best sarcastic post EVA... :chug:
I do have an entire 2 car garage for the build, but then, remember, I'm a fat old cripple. When I move stuff around, I have to use carts, or my cherry picker. I walk with a cane, or a walker, and I sit to do much of the work, either on my walker, or a stool. I had a wheelchair in there at the start, but took it to the VFW so some elderly could use it at the fish fries. (Not really THAT bad) Plus my riding mower is normally in there, but it's off getting fixed right now.
Well, whether by necessity or not, that’s a fantastic area. I’m gonna have a space like that in my next life. Unless o come back as a toaster. Then I guess it won’t matter.
I still like that F bomb sticker. If you choose to replace it during the build, lemme know and I’ll get you one cut [emoji6]
Thanks, I love the sound from Soundstream and bridged to 1 ohm. The rx could handle that. They ran hot but it was double.
Thanks, but the F-bomb sticker will be going away. I want to keep it looking military.
Heard a few bad things in last couple years about getting parts from 4 wheel parts. Been many years for me to order from them.
When I had them do my other truck they did a great job, and the customer service was second to none. That was also 2011.
If your parts are coming from Cali, good luck. They pretty much stopped shipping everything due to the "'rona".
I'm trying my best not to put parts on it from communist territories.
Man it’s a shame that they took so long to assemble your axle, it is better than crawling under your CJ and doing it yourself tho
Ordered the Tru Trac for the rear today. I also found a veteran owned shop that will do the rear axle for me for quite a bit less, so I'm dropping it off there next week. I gave Summit Racing the shop address to ship the Tru Trac directly there. I'll be set to do stuff like work on the tub, brake lines, fuel lines, and the like over the winter.
No photos, but the rear has been done and back for a while. I got it put under the Jeep, but it isn't painted the final color yet, just black right now. Also I won't know if the pinion angle is right till I get the tub back on it and get more weight on it. It was rotated upwards on the CJ5 by the previous builder, and I'm sure it was tilted up too high, so I'll probably need to shim it down some.
Found a fabricator to weld me up a new fuel tank. Turns out the YJ tank I got with the tub will NOT fit in the CJ7 frame. So much for having the filler on the driver side the easy way. He's coming buy Wed to take measurements.
