The LaPlata Mountains in the spring
BusaDave9
Always Off-Roading Jeeper
- Featured
- 3
- Media
- 361
- Resources
- 2
- Durango, Crawlarado
- 1979 Jeep CJ5 with 304 V8, T18 Transmission, Dana 20 Transfer case with TeraLow 3:1 gears, 4.88 axle gears, Detroit Locker up front and Ox Locker in back with 1 piece axle shafts, 36" SuperSwamper SX Tires, Shackle reversal, MileMarker Hydraulic winch, MSD 6A ignition.
I loaded up the CJ early this morning and headed out for the trails. My favorite trails are too high to be tackled this early in the spring but I have some other trials in mind.
This time of the year I need a saw. There are always trees that fell during the winter. I also use my winch more this time of the year.
I left my home in Durango Colorado headed to some lower trails near Pieadra CO. When I got to my destination I found the trail gated and closed. Here is a picture from 2 years ago at about the same time of the year.
This trail would be closed for another month. I headed back west through Durango and on to the LaPlata Mountains west of Durango. These mountains are only 20 minutes from my home but I arrived 2 hours and 20 minutes after leaving this morning.
I turned north at Hesperus Colorado.
Here is the road heading into the mountains.
I stopped to take some pictures of a very old building and barn.
From here the road starts off paved. It then turns to gravel. Later it becomes very rocky. This road going up the LaPlata valley into the LaPlata Mountains doesn't get much maintenance.
I know I wont make it to the end of the road. It won't open that far until late June. I am just trying to see how far I can go.
Many parts of the trail is bone dry, but there are plenty of snow drifts. I kept my OX locker locked and I was able to blast through most of the drifts. Then I see one that is deeper than the others. I keep the pedal to the floor and the RPMs up but I dont' make it through. I put it into reverse and back up as far as I can. Not as far as I would like. I try again going forward but I'm stuck.
Of course my only winch is in front so I winch myself to dry ground. Now I want to assess the situation. Shall I go on or does it get worse. I walk ahead. There is a big avalanche path.
No worry of an avalanche this time of the year but there are no trees in an avalanche path to winch from. I walk on ahead. The snow gets deeper. I decide not to go further but I take some pictures.
I used HDR software to enhance the above picture.
There were some nice waterfalls from the spring runoff.
After hiking around I head back to the Jeep. I have my lunch. It's getting pretty warm as I head my jeep back down the trail.
The snow is very dense. I can walk on top of it and for the most part my CJ was able to ride on top of it. But now the sun has been melting it and it is very wet and heavy. I can still walk on top of it but my CJ keeps sinking in deep. Once my axles start to plow the heavy snow I start to spin my tires. I have an OX locker in the rear and a Detroit Locker in the front. I spin all four tires but I am suck again.
I winch myself out again.
I try to stay to the side of the trail.
If I can keep 2 tires on the dry ground I can stay moving but there are times that trees force me back to the middle of the trail. Sometimes there is snow everywhere. I try to blast through it like a mud pit. I made it up this trail fine but now the sun is making this snow impassible. I was riding up on top of the snow but now I am sinking. I am amazed how deep it is. My CJ was riding on top of 3 feet of snow. Now I am getting stuck everywhere. I Had to use the winch 5 times. Only once going up but 4 times going back down. I thought it should be easier going down.
I have a Milemarker Hydraulic Winch. That thing is a workhorse. It works of the power steering pump. The only disadvantage is it is slow. It has 2 speeds but it will only pull you out in the slow speed. And it's slow speed is very slow but it pulls like a tank. I am starting to think this is getting to be too much like work. But I tell you: a bad day jeeping is better than a good day working any day.
So now I am getting down to lower elevations. The snow drifts are not as deep.
At the lower elevations there are some water crossings.
This next crossing I chickened out. The trail continues just behind (to the right of) the bush in the water.
The LaPlata River (usually a creek at this point) was swollen with spring runoff.
