Build Thread The new guys Introduction/ CJ5 Build / Log Thread
kbarwall
- Maineville, Oh
- 80' CJ5
08 JKU (Wrangler Unlimited)
11' Subaru Legacy Limited.
I thought I would start this thread as a way to introduce myself on this forum as well as to keep track of my progress from the start ( or close to the start).
Introduction/Background:
I am a 29 year old married man with my first child on the way. I am a mechanical engineer by trade. I got my first jeep when I was 16, 79' CJ7 . It was a great jeep and a lot of fun but not a very good jeep for a high school/college student so I sold it when i was 19 for a Honda civic for my long commute to and from school. After about two years I couldn't handle it anymore and got back into jeep with a TJ which I eventually sold for an LJ Rubicon (big Mistake). I sold the TJ for a Rubicon and Wheel base desire which was more of a desire than a need. All the TJ really needed was a solid suspension and some lockers and gears to tackle what I wanted to do...Pictures Below:
TJ:
LJ:
Migration back to my roots:
Once I "grew up" aka graduated and it was expected for me to get a real job I went back to an acceptable daily driver. Don't get me wrong, the jeeps I had were great and quite honestly I wish I never sold my TJ but its hard to balance the daily driver need with something you wheel somewhat hard especially when you didnt have the money to do both, or niether very well. It happened more than once, that I broke something that took longer than a day or two to fix, throwing a wrinkle in my travel plans to and from work.
Present Day:
That brings me to present day. About 2 months ago I decided that with a child on the way I better get my toy while I can. I decided I wanted something I hadnt had before and I settled on the Grand Father of the jeep, a CJ5 . Not to be confused with the great grandfather willys vehicled (CJ2 , 3,5,6, etc). A CJ5 /project toy seemed to be the perfect solution,so I started looking around, as luck would have it, turned out I had a friend of a friend selling an 80' CJ5 in pretty good condition with 112k miles on the odometer with a fresh lift (super-lift 4") wheels and Tires and a SOLID frame. SO i jumped on it.
I don't have any pics from the day I bought it, but it basically looks like it does here with the exception of the winch/bumper it now has. When I purchased it, the jeep had a RUnk front Bumper and homemade Angle Iron Rear bumper...
Pictures:
Roughly 1.5 Months from purchase 4/1/13
Long Term Goals:
As you can see from the Limited pictures of my previous rides I am pretty meticulous and I like my rides clean and I also like things done right. This CJ5 will take me a while to get up to my standards but I see it being a fun adventure/learning process. While I consider myself a decent fabricator and skilled designer/engineer I haven't ever really taken on a project like this that needs some restoration done so this will be my first project with body work (insert scared face). I would like to get rid of the rust (dont we all), finish all the body work, paint and set up for trail riding while give the 5 a modern touch on finish and technology while keep the jeep true to its roots. SO in other words I dont have a set work plan. I am kinda of doing the mods/resto in a somewhat staged build. At the end of the day I will be building for an overland type of build if you will. I would not consider myself a hardcore wheeler but I certainly enjoy using the jeep for what it was intended, I really enjoy just riding trails of various terrains, not a huge mud fun, but that's just part of it here in the mid-west. My main goal, if possible by next year is to get the jeep out to MOAB for EJS. I just had a bunch of friends from my JK crew go out there and it looks amazing!
Stage 1 - Mechanical: Fix all PO flubs, mechanically work through the jeep to get everything working soundly. At this point the list looks like this:
Work completed to Date:
Over the past month I have been pretty busy with work (lots of Travel) and life, so, I haven't had tons of time to devote to the jeep but I have gotten a pretty decent start. SO far I have been able to change all fluids except the coolant (waiting until i replace the hoses), replaced spark plugs, wires, cap and rotor, replaced the wiring for the battery (PO hack job), replaced the horrible shift knob (1/2" bolt welded to shifter by PO) for stock shift knobs, re-worked my TJ bumper and winch plate to work with the CJ5 . I did have to cut and re-weld a 3/8 bolt for the shift knob in order to accommodate the factory shift knobs.
Sorry for the long winded post, just attempting to get my thoughts down to keep myself on track. I am sure I will have plenty of questions along the way.
Hope you all enjoy the pics and the following adventure. I am excited to be back in a CJ!
TJ:
LJ:
Present Day:
Pictures:
Long Term Goals:
- Change all Fluids (Engine Oil, Transmission , Transfer-case, Diff, Coolant)
- Engine Tune up - (plugs, wires, coil, cap, rotor, wiring)
- Fix exhaust leak and build full custom stainless exhaust
- Remove Transfer Case lowering Kit - New Double Cardon Drive Shaft
- Remove Transfer Case and Transmission , clean and repaint,
- ^ replace clutch and rear main
- ^Wire brush frame to bare metal, prime and paint
- Add Windshield, Harness, Various Strengthening bars to cage then remove for finish welding and paint
- Patch Rust hols (cage mount location, Wheel wells, Front fenders)
- Replace Rear Cross-member
- Replace Body Mount Bushings and Hard ware, Fix Body Mount on Body where necessary
- Finish Body work ( filler, sand, prime paint) - Commando Green from new JK's - Black trim
- Refresh Dash/Guages
- Rear Bumper Tire Carrier (Custom Design and Build By your truly - Gerry Can Hold and High-lift)
- Flat Fenders (Front and Rear)
- On-Board Air
- Re-gear - 4.56
- Lockers - ARB Air
- Rocker Guards
- Lights
- Storage
