To celebrate the 4th of July, starting today (07/01/2025) all User Upgrades will be reduced by 10% (thru 07/08/2025) To use this special coupon use the code 2025-4th-10percent at check out. If you are already a supporter your existing package will be extended. Thank you for your support!
1982 Jeep CJ-7 350 Chevy V-8, SM-465 4-speed trans, Dana 300 Twin Stick, Narrowed and locked GM 14 bolt rear, Narrowed and locked Dana 44 front, 38.5" Super Swampers. Fiberglass tub. 6 point roll cage.
I'm fairly certain that any auto Transmission is going to be longer than your T-176 , making driveshafts mods a must. Most auto boxes are bigger than manuals.
A TF727 from an 80's full size Jeep will bolt up between your engine and a Dana 300 . There's a minor issue with one of the pumps or something like that sticking out the passenger side causing driveshaft interference unless you lift the Jeep and/or use a 2 piece driveshaft. I'm not 100% sure about the bolt pattern for the Transfer Case . It may be clocked differently for the NP2xx cases that the full size Jeeps use and the Dana 300 . Though when I pull the 727 out of my truck in the next month, I can tell you for sure. I think the 727 may be a couple of inches longer than the T-176
You can also find a lighter duty TF904 /909/999 in Wranglers (and maybe later CJs). It might be a little shorter but getting the right flex plate for the torque converter may be a little tricky.
The AW30-40 from the YJ/TJ/XJ/ZJ/WJ will bolt up but it's computer controlled so getting it to run properly is an involved process. I'm not sure how the length compares.
Regardless, there's a good chance that any Transmission swap will result in driveshaft length changes. However, that's a cheap fix. Getting a driveshaft or two modified to fit is a lot cheaper than the rest of the swap.
