Tie Rod and Drag Link hitting each other
Humm. . . . .:confused:
The tie rod ends pivot. With that movement it is normal for the drag link adjustment sleeve to tick the tie rod adjustment sleeve.
They don't bang into eachother, do they?
Busa:
Are those spring plates on backwards?
My shocks are behind the axle. Sway bars are in the front. :D
Busa:
:)Well better yet that is an early closed knuckle front axle. Not withstanding the shock mount which is forward tells me that's and early frame also. Check out the welded on caliper brackets!
:D:D:D:D
Busa:
:D:D:D:D
That's not my CJ. My shocks are behind the axle. As Tarry said it looks like an early CJ.
Yuup,
Early CJ5 with some work. Shock location stock ,no sway bars on these jeeps.Tie rods moved to top mounting, also.disc brakes.Nice work and good improvements.
mike
Sorry everyone. I've been out to sea for a week. The first picture is evidence of the drag link adjustment pieces scraping against the tie rod (see the scarring on the rod). The second picture is of the tie rod actually resting against the differential... And the third and fourth are side views of my shackles.
:)TXag88............If you read all the responses it looks like you have an early front end under your Jeep......which is more like a Dana 27 or Dana 25......Couple that with a larger than stock diameter wise Tie Rod and that's where the hitting is probably coming from........If that was a Dana 30 Front axle you would have a little more clearance.............some better photos from the front and side might also give us some other solution's to your problem.
:D:D:D:D
:D:D:D:D
Tarry, I'm pretty sure y'all are all talking about a picture that Busa put up. That's not my jeep. I only put up the four on my previous post...
:)TXag88...........Wow don't know how that got in there....Ok sorry about that...............Let's start this over again....Can you get some better pictures.........from the front and also looking down the tie rod towards the passengers side.........including both spindles where the tie rod attaches and also the drag link coming from the Pittman arm............it was really hard to see much from what you sent...........have you done a tie rod end flip on your spindles?..........meaning putting the TR ends on top rather than coming in from the bottom?
:D:D:D:D
Some hopefully better photos attached. After closer inspection I'm 90% sure the popping/banging I'm hearing is the steering gear contacting the differential. You can see it much better in these new photos. I do think there is some scarring on the tie rod, but when I move the wheel left and right I cant really tell if it's actually hitting the drag link or not... I'll go back out and get the photos Tarry wants now. I can't figure out how to get these pictures to be any bigger than a thumbnail and be small enough for the forum to allow me to upload them
:)TXag88...........those are a little better.......looks like your steering stabilizer is also in the wrong location.........first off the natural geometry of the steering will upon full left or right creep to the rear so that the tie rod is at it's closest point to the rear end cover when the wheel is turned to full stop in either direction............I asked earlier if you had done a tie rod flip? that would also help as by moving the tie rod up a little higher it does not get as close since the front end cover slopes up & back at about the same point..........also it looks like your Drag Link is bent?.............keep the pictures coming the more we have to look at the better we can understand. Need a picture of the Pittman arm and the angle coming from it to your spindle.
:D:D:D:D
Ok, here are a few more; more to come.
Txag88, those aftermarket steering shocks are kind of tricky to install, a lot of guys just trash them anyway along with the stabilizer bar after high lift springs are installed. I see how that drag link is bent, another one of the CJs weak points. Good aftermarket one are available. Thanks for sending in those pics.
Even more coming. Thinking spring sag, extreme angle on pitman arm.
Last two below...
Nothing aftermarket installed that I'm aware of. I definitely don't have high lift springs
The steering damper is after market and it looks like both bars are bent.
Both the draglink and tierod are bent, that has to be the problem.
It also looks like the steering stabilizer mount is hitting the diff. cover.
Right. So I'm gonna be getting a crash course in steering overhaul... We're thinking: HD drag link, replacement tie rod (and flip it), new steering stabilizer. Should do new springs front and rear too?
