Tie rod on TOP of steering arm?
hdgapeach
Old Time Jeeper
- Franklin, GA
- Right now, only one '76 CJ5. 304 with a three speed stick. Everything else is pretty much stock 'cept for a 4" suspension lift. Came to me with a back breakin' 4" suspension lift attached to a reverse shackle setup (Reversed the reverse shackle :dung: and now she rides like a Caddy!) Also posess a few 60s & 70s Mustangs and a couple of late 70's F150s 4X4s.
Bottom up is good too, if you don't get eat up with the hot shavings! I have cut a hole in the bottom of a Solo cup that the bit would fit through without binding, shortened the side of the cup a little and used that to help catch the hot shavings. Works pretty good and only costs a cup!
Definitely use safety glasses, ear plugs and maybe a rain coat to keep the oil from ruining your shirt (remember the lubricating oil?).
