    To dismiss this notice
    click the top right X.
Timing light or all purpose thing-a-ma-jig
Duhwhat
Madison, Ms
1986 CJ7 2.5L 4 cylinder
T-4, Dana 300, AMC 20 rear end
I need to get a timing light and thought maybe I should get some multi-function something.. Not even sure if they make a multi-function timing light. Any recommendations?
I would recommend a timing light and a vac. gauge for tuning a engine.
:agree: I have a plain timing light and never felt the need for anything more wiz-bang. The vac. gauge is also very handy for tuning and finding problems. A compression gauge and a leak down gauge are nice to have also.
One disadvantage of owning an expensive timing light is when the wires get caught in the fan.
:laugh: or get melted by the headers.
Pick both of these up at Sears for $50 - $75 and that should be all that you need :chug:
I have one of the digital advancing timing lights. not sure it is a great and wonderful thing but it also has a tachometer on it. You set the advance and just tune until you line up on 0 deg. If you really wanted to set the timing at 20 deg before, you could.:cool:
no matter what anybody says, I do not think a decent timing adjustment can be done by "ear".:D
I have a hand vacuum pump with a gauge on it. It tests vacuum lines and switches, bleeds brakes and measures vacuum when the engine is running
$100.00
  50.0%
