tire size
tire size
highwire
Rutland
1979 jeep cj7 304 3 speed
1986 cj 7 renagade auto ( wifes)
I have a stock 86 CJ7 what is the largest tires i can get under it with out lifting it, A guy told me 33's will fit. I don't think so, Jeep is stock and realy don't want to mess it up with a lift, but want to but some real rubber on it????
31's without rubbing
32's will rub
The issue is the diameter of the rear wheel well. With a little trimming you can fit 32's. (can't trim much in front of the rear wheels)
No problem in front.
You also have to remember that your stock springs have dropped unless they are new - 31" may be the largest you can go.
depending on tire width you may want to look into a set of shallow back space rims. with the wrong rims the front wheels will rub the inside of the fender/spring in the turns.:cool:
$35.00
  17.5%
