Torx Seat bolt
Torx Seat bolt
ken98k
North Pole, Alaska
{1980 cj-5, 258, t-176, d300 amc20 rear, D30}{1974 cj-5, 304, T-15, D20, D30 front, D44 rear}{1973 cj-5, 304, t-98,D20, amc20, D30}
{1990 yj 2.5L i-4 AX-5 NP231 Dana 30 front Dana 35c rear}
1996 XJ Cherokee 4.0 HO
{2000 silverado}
{1979 Cadillac Sedan DeVille}
I'm replacing the seats in my 80 CJ5 and broke 2 of the e-torx bolts that connect the slider to the bottom of the drivers seat.
Does anyone know of a source for these bolts?
Unless you're trying to keep everything 100% stock, I'd use a Phillips head screw or a bolt. Torx head screws and bolts are a pain. You just need to make sure that whatever you use, the head clears the slider. I've been there before.
I am trying to keep it as close as possible to oem.
These are the external torx and use a torx e10 socket to install or remove them. As near as I can figure they are 5/16-18 x1" thread forming
as they are sort of tri-angle shaped.
You could use a grade 8 hex head make your life easy finding a bolt that will work :chug:
I don't think that the hex head bolt will clear the sliders.
That's correct, a hex bolt wont work.
The e-torx are superior to grade 8 hex bolts.
With the correct wrench, it's impossible to strip round the head off, and they're stronger than grade 8.
Plus when I pass this rig on to the next owner I don't want him to have any grief because "Bubba PO used the wrong parts"
Interior Seat Covers
Brakes 10 or 11
$100.00
  50.0%
