Tow hitch recommendation
How can I lower a factory hitch? The trailer is level at 18". My factory hitch is at 21" before I do an SOA.Does it not have a factory hitch? It should work just fine for you.
BTW - :ww: to the site!![]()
Hi,
I'm a brand new 1977 CJ-7 owner - on the truck being delivered as we speak. I want to pull a small trailer for hauling firewood. Anybody have an opinion on towing gear - who to avoid, who to buy?
Thanks!
will either of these work for you?
Jeep CJ7 Hitches - JCWhitney
Hidden Hitch 1977 Jeep CJ-7 Trailer Hitch | etrailer.com
I was thinking the same thing, but I can't find a 2" receiver that will fit because I have the 20 gal gas tank. My father has a Reese hitch for a GMC, but I'm not to sure I can modify it. My friend is certified welder so puting it back together is no problem just a lot of work. Buying a bolt on for 200.00 sounds easier but I can't find one.
Anybody know of a bolt on 2" receiver that fits closely to the frame width of a CJ-7
If you have a friend with a welder, its not that hard to build a rear bumper and add a receiver hitch into it.
I would check the rear frame for rust as mentioned earlier, and tie the new bumper to the frame in a few spots with tie plates.
