tranny stuck in 2nd
tranny stuck in 2nd
penster1
Yuma
1980 cj5
258 cu 4 speed
All
1980 CJ5 4 speed. I have had these jeep several months and twice it has gotten stuck in 2nd gear. PO says it happens once in a while and he showed me how to fix it. You have to take the shifter boot off and pull the shifter out, realign the shifter clogs and put it back together. Anyone else have this issue and is there a permanent fix?
I had the same issue. I bought two new pins where the shifter goes down in and it hasn't happened since. I think they were $15 for the kit from 4wd.com.
Yep, I think they are about $2 each. I bought a kit that had the boot, 2 pins and something else in it "can't remember", I looked for it on the website and couldn't find it. I'll look in the catalog tonight when I get home and see if I can find you a part number.
the T-176 in my J-10 did this. I replaced the shifter, the lolly pop looking thing at the bottom end was worn to the point that it would miss the notch when going for reverse.:D
Yes I believe its a 176 and it seems to do it when I try to go into reverse.
