tranny swap
Any of the chevy auto's should bolt up. You will need an adapter for the tc.
You will have driveline problems though with the CJ5 being so short.
With you having a V6 you might be able to move the motor as far forward as
you can and get away with it.
Even after moving the engine as forward as you can, look into CV drive shafts.
I would go with a Dana 20 tcase s that is about as short as you can go
now depending on lift, yes driveshaft issues are going have to be addressed.
However, if you really need that auto, then the issues will be a one time item to get over and you will love the jeep afterward.
