transmission cooling lines
trw
I get my CJ running again, and the Transmission cooling line springs a big leak.
its leaking on the flex line, right where it hooks up to the radiator fitting. Its leaking right on the funky coupler that allows the hex AN fitting to rotate within the rubber flex line until you tighten the clamp.
I might add this is on a 78 AMC 304 V8 with GM Turbo 400 auto, I can't find anyone who carries a replacement line for this and I'm currently not in a position to install an auxillary cooler, so I'm not sure what to do at this point.
