Transmission noise.
jb8376
- florida
- 1983 CJ7 with stock nuttered 258, T4, Dana 300, Dana30, AMC 20
I have a noise in my Transmission or somewhere in the driveline i cant figure out. All ujoints, wheel bearings, clutch flywheel pressure plate etc. Is new. The Transmission is completely rebuilt. I have had it out 5 times now and can't find it. The noise only happens while coasting , the Transmission is in gear and the clutch pedal is pushed in. I do have a new 2.5 lift, and 1/2" lift in shackles. Ive installed a new double cardan driveshaft also. The only thing i havent touched is the Transfer Case . I dont think the noise is from there but i have a friend who has an extra that he is going to let me borrow. I will install his to rule that out. Any suggestions? Any help would be greatly appreciated. Below is a link for a you tube video of the noise.
https://youtu.be/b_5heV45PaQ
