Transmission problem! T150
polish85
I was pulling the Transmission from the Transfer Case to replace the gaskets and while pulling it apart these bearings fell out and im not sure where they go exactly. If you look at The Haynes Manual diagram it looks like the bearings go at the end of all the gearswhere i circled in red. Is this an easy fix to put them back in or do i need a professional to do this? Also do i need to set the sprocket in a certian position??? I dont know anything about transmissions so anything will help. Does this transmission look in good condition?
Thanks in advance!
