Tub and electrical revamp/rebuild.
InfidelOffroad
- Media
- 9
- Gulf Coast, FL
- 1981 CJ7, 258 I6, T5
1986 IRoc, 383, TH350
Hello all,
It's been quite a while. Here in the near future I plan on removing my tub, painting the frame and tub, then rewiring the entire Jeep. While the tub/frame will be pretty straight forward, I had a question about the wiring.
Should I go with a Painless Harness, or just fully wire the Jeep myself? I have a 1 wire HEI setup. Last I read you can call painless and tell them what all you plan to have wired, and they will sell you the best kit. On the other hand, I feel that I can make my own harness for a lot cheaper. A Jeep isn't rocket surgery (especially a CJ). If I were to go my own harness route, any suggest any universal fuse blocks? I was thinking something like SEAL-ALL MINI FUSE & MICRO RELAY PANELS from Aircraft Spruce .
I would then replace the bulkhead connector with cannon plugs for each system.
I plan to use this time to take several pictures if not YouTube videos of the process. Hopefully it can be of any use to the next guy.
