Turn Signal Switch trouble
BBCJ5
Texas
1980 CJ5; AMC 304; dana 30 Transfer case; T176 Transmission; edelbrock carb
Anyone know of a simple way to fix or replace turn signal switch? Hazard knob works fine so I think the grounds are all good, but the lever on the column doesnt make the T/S work. It used to but you would have to hold it in place, now it doesnt kick on at all.
steering wheel pull...you need puller and a gm compression tool after that your looking for the pic below..that is the turn signal/flasher....look to the left of pic you see a metal strip....that is the turn signal contacts(most of the one i have encountered has old lithium grease )
if you go that far spend the extra 20 and replace the ignition switch ( with key) your only 30 seconds away
but let brock, CJ, petescj, Bajaedition, and IO port chime in on this they definatlry know whats up
