Turn Signals
Turn Signals
81laredo
Idyllwild, CA
1981 CJ7 Laredo as built, 1952 Pontiac Sedan Delivery, 1955 Thunderbird, 1958 Airstream, 1996 Tahoe 4X4, 1982 Newell Coach, 1957 Cabin in the Woods what will I work on next?
I just replaced the Turn Signal Switch on my CJ7 . Everything appears to be working except it will not cancel after a left turn. Does someone have a Parts Breakdown Diagram that could help me know what part to replace so that I can have it in hand prior to removing the Steering Wheel again. Tilt Wheel, I also need to replace the Ignition Lock.
Thanks in advance
its cancelling on a right hand turn?
how tight did you tighten the screws would be my first look
the cancellation springs in the pic are at 10 and 2 o'clock
and the hazard is a 6 o'clock
Thanks but I am looking for the Steering Column Parts. The new Switch is from CROWN and does look like that pic but doesn't show the Canceling Device.
still looking
Thanks, that helped. I'll call them to look for the part.
is there a way you can post a pic of your column?
Thanks for the consideration but there really isn't a need. The parts breakdown showed the Cancellation Cam (item #9 for a 1981 steering column with Manual Transmission )
yep
that will help as well as if you want a horn
good luck sir
$45.00
  22.5%
