turning knuckles on dana 30
3wheelingCJ
I did a 2" lift with 1" shackle lift and now my caster is off. Put in 4' shims and the steering got better but I'm still a couple degrees shy of perfect.
I'm looking for different options on how to fix it. My preferred method would be cutting off and turning inner Cs, but I'm lacking necessary welding skills.
My second option is to get 6' shims, but I don't feel comfortable with that in the front axle and the center bolts will be too short. Also planning on upgrading to 33" tires from 31" and that will affect the caster as well so 6' shims may not be enough.
I have to keep the shackle lift because the new hangers were welded in place to accommodate the extra length (don't live in the same state anymore to have the same person do the welding again).
Any suggestions?
Anyone knows a welder in the bay area that can do the work? I was able to score an empty housing, so no need to take anything apart.
New springs are bds.
Thanks in advance
Any suggestions?
Thanks in advance
