    To dismiss this notice
    click the top right X.
Upgraded wheels & tires forces a spare tire swing.
JeepDat
Kenmore, WA
'85 CJ-7 258 D300 Twin Sticks AMC20, D30
That is to say it forces a new/upgraded tire swing..
Poor planning on my part, but much to my dismay, my new 33" spare will not fit on my carrier/swing. :eek: I had to throw it in the back to get it home, and leave the old wheels there to pick up another day!
So...if you all have a tire swing that fits 33s I'd like to see it, Manufacturer and/or retailer would be helpful. I'd really like a swing that I could mount my hilift, maybe a shovel and/or Jerry can.
The thing is, I'm not set up to fab anything anymore, so that's not really an option...some day I'll have a proper shop again.
Thanks in advance :chug:
I'll take pics of the carrier when I can see the Jeep in the daylight, but for the curious, here's a pic with new wheels & tires on.
Warn, found the set for $AMC 150 used.
I like my warn as well but there's no way to mount a hi-lift or jerry can
Adding a hi-lift jack to a rear warn bumper is easy enough if you have a welder. However, the jerry can would need some extra tubing to get it done.
What's the largest tire you can put on a stock carrier for a 84 CJ7 ? :confused: I am getting 35x12.5 but I doubt that will fit.
If it's the same swing out carrier as mine, I had 32s on there, but my 33s won't go.
Hmm. My buddy has a 78 Levi (Edition) CJ7 and I am pretty sure he has a 33x12.5 bfg AT on there. His carrier is kind of loose though. The tire kind of hangs out a bit because of it.
Mobile Photobucket
His is the brown one. The second video is him and there is one pic that shows a side pic.
Can't tell you how many time I've noticed the mounts being pulled out of the sheetmetal because of someone mounting a large tire on a stock carrier.
Personally I wouldn't mount a 33" tire or larger on a stock carrier. They were not designed to handle the weight.
Mobile Photobucket
The pics are tiny yet still take forever to load, but it looks like he's using a lower profile bumper. I've got the double tube bumper, which probably sticks up a bit further?
$40.00
  20.0%
