upgrading suspensions for a noobie
raser13
- festus,MO
- 1977 CJ-5 '83 amc 258 straight six, motorcraft 2100 carb ,inline fuel pump, 1000 cca battery ,T-175 tranny,
thanks guys, this is the kind of info i needed. i didn't think there was much between 33s and 35s. my 31s have done me a great service. i was figuring that the larger diameter tires would make it easier to traverse the lager rocks and crevasses. and for the coil spring set up. most of the folks here are running them. figured there was something to them. that's why i'm here asking questions. if my current jeep is good enough to try to run this type of terrain i'm also good with that. i just don't want to drive a few states away to have fun. and come limping off the trail because i didn't do my prep work.
i'll check out the books out on amazon and start doing my home work so i can come back with more targeted questions. i guess my best questions to ask now is if any of you are in the southwest area or the Colorado area. what are you running? and what does it take to traverse your area. i would assume Colorado is close to Missouri terrain. just a bit more up and down.
i've been in the deserts of el paso tx when i was stationed there in the army. the humvees did great in the sand. and i figured my jeep would to. but i never really got to play up in the mountainous areas. so i really have no frame of reference. well you tube videos of these really over powered rigs that have like 10K worth of bolt ons. so i really don't know what it takes. i figured i would at least need to upgrade the suspension. but i will figure out all of my gear ratios and add them all to my stats. and come back so i can be better tuttled by the masters. thank you all for the info and for the knowledge of what i need to know so i can supply you with so we can figure this out together.
