v-8 conversion
The three with red circles are different from a six cylinder Jeep.
Hello davidyoungdoff and welcome to the site! :chug:
The V8 conversion is relatively easy and is very popular. You need (as Longhorn mentioned) a new frame bracket (pass side), block brackets, rad hoses, heater hoses, exhaust, possibly some assorted wiring, flywheel, possibly clutch linkage, possibly a better radiator, throttle cable, you may need to move your Transmission mount forward or backward a bit and a few assorted odds and ends.
Just about everything you need is available in the aftermarket.
Here are another thread discussing this topic.
http://www.jeep-cj.com/forums/f2/v8-conversion-cj-5-a-722/
I am also doing a V8 conversion now. I'm running into some trouble getting all my ducks in a row before I start. The 350 and 700R4 a got came with a NP208 transfurcase. Will this work, or will I need to get a kit? I know in the late 80's Chevy switched to a driverside drop. Please let me know what you guys think.
Its already mounted to the 700R4. Will the whole assembly fit under my CJ7 . Its from a early K5 Blazer. Sorry for the confusion and thanks for the help.
Its already mounted to the 700R4. Will the whole assembly fit under my CJ7. Its from a early K5 Blazer. Sorry for the confusion and thanks for the help.
I'm not positive but I believe you should be OK. If the output for the rear is on engine center and the front on the correct side I don't see a problem. You may have to change the clocking of the Transfer Case to the Transmission though (if that is even possible).
Im also trying to get rid of my 258. Should I keep my Dana 300? Is that a better option?
Well the Dana 300 is a great transfer case and pretty much bullet proof under most applications (and it doesn't have a chain), it really deepens on how easy you want to make your swap... :) Novak has an adapter for the 700R4 to the D300 also. -->> Adapting the 700R4 / 4L60E to the Jeep Dana 300 Transfer Case
I guess the other question is what axels. Hahaha, it never ends! Thanks for your help.
Trans 81 CJ8
