Build Thread Vader , A multi year Cj7
Man i need to start building a trailer
You will get there. It’s only week 54 or thereabouts.
It's crazy how time can get away from you. I knew owning my own home would take up some tie but I underestimated it. I have a couple grand worth of parts to throw at the Renegade just sitting in tubs in my garage till the time is right.
Finally had some help today and was excited to get the brakes bled and tested. That ended pretty quickly. Can't get fluid to the bleeders. Have no idea why. Just disgusted.
Did you bench bleed the MC?
Yes I did. When I went to put it in the Jeep though the brake lines were reverse of the originals so I did lose some fluid. I didn't think it was any huge concern but now that's where I'm starting at. I'll take it to the bench again. I actually have two weekends off in a row so the kid will come up next weekend thankfully. Just hate the delay.
I had trouble years ago bleeding mine after putting a new MC on it. Thought it was bad out of the box, but read some articles and talked with my mechanic buddy and the concensus was the porportioning valve was stuck in the middle position. The fix was to start bleeding the fronts first, then rear, and back to fronts to finish. It worked oddly enough. 🤞this is your problem.
Just make sure you have plenty of brake fluid on hand before you start
Well if bench bleeding the. Master cylinder doesn't work I'll go there next. I actually came up with a pretty good YouTube video of a bunch of possibilities. 1 large bottle of brake fluid $13.50. I miss mean tweets. 😔
Bench bled it again. Same result. Maybe I'll try the old master with the new booster and see. This is just irritating. Don't get anything front or rear.
You are correct in trying the old master. Nothing is not saying you got a bad new one! :cry: :td:
Yup got flow now. Unfortunately two bleeder screws are crusty. Had enough for today. I'll get after those either tomorrow or Monday. At least I know where I'm at now. Blood pressure is coming down. 😊
  5.0%
