Volt Ohm meter
Volt Ohm meter
IOPort51
Featured
Garland Texas
1977 cj-5
2006 Toyota Tacoma
There are a lot of questions on this forum about electrical systems and the challenges they present. I have found that the one tool that is absolutely indispensable when working on a CJ is a VOM, volt ohm meter. I have the opinion that 99% of these problems will require a meter to solve.
For my own curiosity I am posting this pole. It's totally anonymous if you like.
I would like to know if you own a VOM, Know how to use a VOM and if you own a VOM and know how to use one.
When I say "know how to use one" I am referring to being able to being able to tell if there is voltage to a load, weather a relay or switch is open or closed and even how much current a load is drawing.
Good Question. I finally went and got a cheap analog VOM for troublshooting other things. I used to have a really nice digital one, long ago, but for $10, the one from Lowe's works just fine. we used to use them at the cable company for chasing shorts in the main line, or finding shorts in house wires. They are an indespensible item for troublshooting any electrical issue.
They don't have to be expensive, although I have a couple that were better than $200. I got a digital at Harbor freight a couple of weeks ago that will even do DC amps up to 20 amps, worked great to size the fuses and the wire for the new PDC I built. $20 and the only thing I don't like about it is it does not turn itself off.
The cable company bought us the expensive Fluke meters. They worked great, and were shock resistance (you don't always mean to drop things from the pole, but it happens). $20 sounds like a great deal, I could always use another tool.
Every garage should have one or two in case one has dead batteries witch you can check with the good one. :D
been there done that:D
When I was installing wiring in 767s, I had a couple Fluke meters. Both of them got stolen with my toolbox a few years ago. Never had a good reason to pay over $50 or so for one since.
I had 2 at the start of this weekend, now I have 1. RIP to the oldest one I had, due to a failed circuit somewhere. I even checked it over with the other one! LOL
I've got a couple. When you need them there's almost no substitute. Though a length of wire and a spare tail lamp bulb will do in a pinch when you have nothing else.
Still, I like to have several since I can never seem to find the one I'm looking for.
Purchased one a while back to use to test my battery and alternator. I then purchased a couple more at Harbor Freight in there bargin bin, as back ups, since they were inexpensive. I don't have much experience with them yet, but plan to learn/use them when I rewire. Anyone with newbie guides/tips for using them, please post a link for us who are just beginning. :D
I did a google search and, as yet, have found no tutorials I would call great. keep looking.
while busadaves explanation is good almost any meter bought new will have a small instruction booklet on how to take basic measurement and do basic tests with the meter. even the little el cheapo ones from harbor freight has them. i got one of the little cheap ones for free from hf and it came with one. little note to anyone who is interested hf will honor online coupons in store thats how i got the little red meter they have for free. at the time it was only like $5-$6 but hey i got it free.
Just a little plug for the cheap meters. Most are analog (needle moves across the scale), and actually put a very small load on the circuit being tested. Digital meters are much more sensitive, and this can sometimes, but not often, give false readings. I have seen digital meters show voltage through the carbon track in a blown fuse.
Main thing to remember when using a VOM is volts is volts and ohms is ohms. Volts on the ohm setting will smoke the internal fuse.
$100.00
  50.0%
