Warn power Cut-off switch
JR74CJ5
Missing-Presumed Wheeling
Lifetime Supporter
Plumas Lake, CA, USA
1974 CJ5 ~ Fresh built AMC 360 - SM420 - D20 - D30F with upgraded 30 spline shafts and knuckles & D44R - 4.27 Gears - ARB Lockers F/R - All chrome molly axles - on 33's - YJ 4" Lift Spring Conversion
Hay all,
Wondering what you all have done for a cut off switch for winch.
Heard a few horror stories of shorting in the middle of the night and ripping the bumper off / burning up the motor etc. That was due to rain getting in a control box i believe...
I couldn't tell the best place or way to do it. :notworthy:
~ JR
Just get a toggle switch that is within the correct amp limits, mount it where you want to and wire it between the main power for the winch and the battery/fuse box (however you choose to wire the power for the winch).
Wow, I"ve never heard of that and most people I know run a warn.
You will need something like a battery cut off switch to handle that kind af draw though.
I'd check summit racing, or somewhere like that.
Didn't appear to be too common of a problem... I think I read it on Pirate4x4 or somewhere...
Year guy woke up next morning and the winch had ripped front bumper off, and was toast from continuing to try to retract already fully retracted... :eek:
That would :censored: me off man...
Yeah I'm thinking a boat style cut off switch would work... Now just need to figure out if I just want to put it under the hood, or try to route into the cab...
~ JR
could you install a kill switch like they use for a boat or sea do...where the lanyard could be attached to your keys and then when you pull the keys out...it kills the power to the winch...that way you could never forget to hit the "main" switch?
Didnt think of that.. Ill look into it. I would need to occationally use the winch out of the jeep, but i could always leave it in the jeep ...
Hmm. Something to ponder more on. :rolleyes:
I still think i will just get a boat / rv battery kill switch,
Like this: http://www.amazon.com/gp/aw/d/B00144BF9Q/ref=redir_mdp_mobile
but will look into this more. I like the idea though :chug:
-JR
Thanks all! :notworthy:
Ideas a flowing... Going to post up what i finally use here and in my build thread...
