water pump pulleys for short 225 V6 pump
oldjeeplady
Full Time Jeeper
Lifetime Supporter
Eagle, WI
1979 CJ7 V8 304 T18 w/gran low D20 w/TeraLowD30 D44,
1959 CJ5 Rebuild 74 Buick 231V6 oddfire T14 D20 D30 D44 frame boxed roller engine ready,
1967 CJ5 V6 225 T86aa D18 D27 D44 runs needs work,
1954 CJ3B F4-134 T90A D18 D25 D44 Half Cab needs tub,
I need some help here.
Our engine is a 75 Buick 231 V6 oddfire, but the water pump on it is way too long and the shaft goes past the radiator..:eek:..forget the fan.. and the extra clearance needed when the engine revs (or so I have read..) We plan on electric fans maybe even mounted in front (push?) of the radiator. That's how tight our space is up front.
We have a stock 67 CJ5 w 225V6 and comparing the water pumps it appears this model will work for us. We are installing PS, so we need both the crank and water pump pulleys that will work for this.
My question is:
Are we stuck trying to find V6 Dauntless Buick 225 V6 pulleys? Or is there some other vehicle/engine where we can look for the pulleys. Our 67 is a single groove crank pulley, but I think I have seen them in a double groove.
mstar or tarry99 - I thought I saw some pics of this in one of your responses to another members question on upgrades.....but I cannot find info on pulleys...Maybe it's there and I just cannot find it....:confused:
Using this 231 oddfire has required lots of searching for parts and coming up with nothing....:rolleyes: or I am just an idiot...:o....OK don't answer that last part...:)
Any help would be appreciated!!!:)
My question is:
I sent you a PM...........the pulleys from a later 231 Dauntless Buick 225 V6 or V8 should work.......look at the other post you made on the same subject.
:D:D:D:D
