Engine Water Pump
Engine Water Pump
Scout1067
Old Time Jeeper
Germany
1981 CJ7, 258, T176, D300, D30 front diff, AMC 20 rear diff, Weber Carburetor, BDS 2.5" lift
Any recommendations on a good OEM replacement water pump for a AMC 258 i6 / 4.2l ? I still have the OEM radiator with no plans to replace since it works just fine. My water pump is starting to make a funky chirping sound though as if a bearing is giving up the ghost. I am looking at the FlowKooler 1745 it seems pretty good and they offer a 2-year warranty.
i put an ac delco on mine been 3 years now with zero problems
Sent from my E6810 using Tapatalk
Do you happen to remember which part number it was? Summit shows 3 different AC Delco pumps for that application.
i got mine from Rock Auto
I will check them out
There's 2 WP's for the AMC 258 i6 / 4.2l . They have different impeller rotation.
Make sure you buy the correct one.
$35.00
  17.5%
