webber
webber
kenpoman2003
Whitefield, Me
1986 cj7 4" suspension lift, 2" body left. am going to install rear bumper tire carrier, front bumper brush and grill guard, front roll cage and tie in kits. all as money becomes available. dana 30 front end with quadraqtrac four wheel differential. amc 20 locking differentail in the rear. Have solid piece axels just waiting to be installed some slow winters day hopefully in heated garage. Am also going to do, do it yourself paint in tub liner havent decided which one to go with. Any sugestions? hope to do this to the underbody and frame as money allows. I have ordered marine interrior lights for under dash and bach passenger compartment and under hood w/ heavy duty toggle switches. I plan to install a secondary fuse block to acommidate any accessories I may someday get. I know it sounds like a lot but its a pick away project with no deadline. and as money provides.
I'm looking to put a stock air cover on my webber carb. Can this be done reasonably. Is there a conversion plate to do this? If so where can I find one? I've googled and am un able to locate somthing that might work. If any one can assist me will be appreciated
Thanks Jon
I would say it would have to be custom made to fit between the oem air cleaner and the new carb. It would probably be best to do it like that to still retain the fresh air system. Do you know anybody who is a machinist?
i used a 4 inch to 3 inch rubber addaptor from pepboys $16.95 and hose clamps but i just made a cold air kit with a 6x6x4 electircal box traced out the shape of the webber carb inlet and cut then with a hole saw cut a 3inch hole in the front and bought a 3inch air intake pipe (from pepboys like $15) and pvc glued it in and air box from a junk yard 3inch inlet and ran a rubber hose
