Weber 32/36 for 2.5L
moranna
Newbie needing advice on Weber 32/36 setup for 85 with 2.5L 4
Tossed the Carter, did the Nutter bypass and stripped out all of the stock emissions (electrical and vacuum). Totally bypassed the computer.
Installed a Holley regulator set at 3.0 PSI with new fuel filter (with out return line).
New plugs and NAPA Belden wires and timing at idle is set at 8 degrees advanced.
New PCV valve hooked up to large nipple on the Weber.
Idle jet backed out 2 1/2 turns and idle adjustment screw turned in per instructions.
The new carb cranks well and idles nice when electric choke is on but as soon as it warms up and choke disengages it begins to idle unevenly with RPMs rising and falling and with a slight misfire. Tends to stall out when in gear and clutch in although it seems to run out well (for a 4 cylinder anyway) once moving with no hesitation or misfires.
My first thought is a possible vacuum leak at the maniforld adaptor. Should the Weber be mounted using a sealant?
If so what is best to use?
Any other things I should check on the weber before reinstalling such as the jet sizes, float level setting or butterfly valve setting?
Sorry for long post but and advice greatly appreciated.
