What are these wires/plugs?!?
jerry1847
Arlington VA
'80 JC5 flat 6
Getting ready to run wire for my CJ (radio and CB) and see a couple connections that are not being used and i dont know what they are for. I dont think i missed them when i was reconnecting the dash but i could be wrong.
Maybe one is radio and i can use it and not splice anything? If anyone knows what these are it would be a huge help. Thanks!
First on is in front of the fuse box on the driver side and had an orange and black wire
the sesond is to the right of the steering columb and has a purple, black and yellow
The first one the orange and black should be switched power and ground. The other plug should be for the speakers.
Not sure on the second photo. :D
sounds like the first set (orange and black) may be good for nothing :). I may use it for the CB(dont think i will use it much if ever while off)
hoping the 2nd set is a constant and switched i can use with the radio....
If you look at the fuse block you will find a couple of accessory stake ons you can use for this. I suggest you use a relay with power directly from the battery for the CB, it will reduce the engine noise.:cool:
Not the first time I have read about the engine noise. Is it that bad? I'll probably go that route for the cab.
Anyone know what the plug second pic is?
looking at wiring diagrams it appears that:
Orange = bulb
Purple = switched gague power?
Yellow = constant power?
Anyone? Bueller?
