    To dismiss this notice
    click the top right X.
What does an egr and a pcv actually do?
VT Woodsman
Northern Vermont
1978 cj7 304 v8 , 4speed which i think is out of a newer cj. Im pretty sure it has a stock transfer case.
Thanks fellas.
EGR is exhaust gas recirculation. It introduces a specific amount of CO (carbon monoxide) into the intake manifold. as it turns out, this improves fuel efficiency, reduces emmisions and smooths the idle. As the idle goes I won't say it smooths the idle but if you don't have a working EGR it won't idle as smoothly.:cool:
PCV Positive Crankcase ventilation valve. Allows cylinder blow by and oil vapor to be drawn from the bottom end of the engine. I think the valve is to regulate the amount of vacuum used. with out the valve it would be a large leak.:cool:
Thanks fellas.
The PCV valve is only a check valve. It's only really there to keep air flowing in one direction. That is, from the crank case to the carburetor.
$40.00
  20.0%
