What else could it be?
Reddrig
- Ca
- 1972 Jeep CJ5 304 T15 Dana 20 Holly Carb
Dana 44 rear
Dana 30 front 4.27 stock gears
Front and rear power disc brakes
35" Mickey Thompson tires with Mickey Thompson 17" wheels
Rhino lined tub with custom tool box
Rugged Ridge ORV 4" lift, 1.5 BL
I need some suggestions, help me solve this problem. I'll post pics of the suggestions to see who can identify and help me solve the problem.
My T-15 Dana 20 is still leaking. The problem looks similar to a rear main seal. Oil leaks after engine starts running approx 5 min, small leak few drops per minute. The oil seeps down between the plate on the tranny and bell housing. So it's behind the plate and comes through the small crack.
Rear main seal replaced twice with exact same leak and flow still present. Used all the tricks and am sure it's not rear main. Valve covers are not leaking either. Replaced and tight as a drum.
What seals are between the bell housing and tranny that could be the problem? This will be interactive. Once I gather the logical fix from you guys, I'll try it and see if it works. So fire away.
