What happened to a great thread?
mscottb
northport,maine
1980 cj5 258 2bbl 30 in the front and 20 in the rear.
2005 vulcan nomad 1600, 2004 6.7 diesel f-250 super
I am having some idling problem with my AMC 258 i6 / 4.2l w a carter carb ( a common problem I see) and I ran across a great thread from a gal named ranchgirl way back in 2010. I was following along cause alot of her issue were similar to mine, and then it seemed to stop in mid stream anybody now the outcome did she get the carter carb working? kind of like comming to the end of a book and finding the last chapter is missing:eek:
This one,
http://www.jeep-cj.com/forums/f2/vacuum-emissions-5354/
The original poster may have found a fix for her problem with the advice from this forum but failed to post results. This is a good example why posters should follow through when they start a thread, as you can see it helps many others when final results are posted.
I'd suggest starting a new thread.
