What header to use for 4.0 head
That's the same one I used. Mine being a '93 however, doesnt look like anything changedI'm using a factory cherokee exhaust that I paid $25 for, saw no need in spending $500 for anything aftermarket. Don't remember exactly what year but 87-90ish? rings a bell. It's tubular with a 2-1/2" outlet that points in the right direction for a CJ, so far so good. One thing though is it is tight at the PS pump bracket that requires a small dent in the header or trimming the pump bracket.
I like the clifford header , it has two 02 sencers do I block off one?
I dont know if that would be an issue with a visual inspection or notInstalling the Howell with the 4.0 head . Would it hurt plugging one bung then use the other?
I also need to find a intake that will work.
