What is this?
I would think heater as well. Can't see inside under my dash because of AC unit. Also, the hose on mine is not capped off but has a flap exhaust type set up.
It is attached to the fresh air intake of the heater box. It is a drain for the water that gets into the cowl vent.
It is not capped at the end, it opens up to let water out.
If you don't have a screen covering the cowl intake, it is a good idea to check occasionally to make sure it isn't clogged with leaves.
Don't loose the end, they are near impossible to replace.
Best pic I have of the inside. See the round piece that is at the bottom of the intake above the heater box.
I449Q8wOSx0NYTaOBIqNeNXLTnGT9no5taMGN9rBHPgoG_5uITaYmGSUegTZVGrMk2Yu43jQHmAA4_9VgvT7r4zA6vbHBSp3VoZI30sjh9zbJQ1AeYFEx5PNECI5QiOeQACyktHlwDTq0IckzqwoHQevR8gNa1Fgy5dHi7brzi7rfn3NUCBeP4GW2XMitny_gejkpoB4bYiSfB_2JpL5m2J6vvX6AE5TSO_eT50GGbix4Hg8N4jgmNMw-C28oUhD9t4jagokPHY2UoiSwOMnAYEDxAb1FxM2VbGkRI57czaSUdRLAEyIuo_tNXs6WGmmr4JGzXe2vRQf9Sr3-Vz6AaG68-M1i9JXdQ9RxyjXLJpGs_HV_GsOi9EwXb4A5jECVvpLs2PpW9O27m5gzRv7ULNIentp4im-Qiq_z5TtNP9JK-MSxDgZLcxnj-dWku1fjz3ixHv-U9rwPN5ul_M4EXp2iJquCKu3Sg_4yLt7oxi_GR7Dh6GullTnvlLS0hTJ3M2EEUjZe1aNb5ix1nXSDWbtgHS9Dw09wUbXbK9WsbXVXh-7aDfVtgeZ4FSBGAtcbAqOO6smVmQ3uLx32KoMlVjlkz4syl9uIAxhjjyiULnVV2ILWA=w1000-h750-no
