What is this?
What is this?
EVERYUSERNAMEISTAKEN
Houston,TX
84 CJ7, 4.2L, D300, D44's w/ E-lockers front and rear, 4.88's, 4" springs, on 36" TSL's
What is ^^this^^ bolt called and where I can buy them? Thanks in advance to the CJ gurus!
These bolts slide in the channel on the rocker panel and hold them onto the body.
This is one of the few forums where you not be flamed for asking questions. So ask away! :)
You'll get poked in the ribs, but not flamed. LMAO
Who needs these anyway a piece of plate and a bolt ..make ya own lol
Now we're talkin!! I was hoping that these would be cheap but they are not. I'll probably goto my local bolt& nut store and see what we can come up with.
Elevator bolts...... and something to sleeve a portion to prevent over tightening......
I'd go get a strip of .. 1/8 I'm guessing is the thickness ..cut and weld some threaded rod .. good call on over tightening .. round bar stock with holes drilled for some massive washers I'd say us easy
I'm thinking if you have a welder they wouldn't be to hard to make.
If you use elevator bolts, there's no need for welding....... just a spacer for overcompresion
I like the ideas! This is for my FIL's CJ7 and he only needs 3 of them. I think the plan is to basically do what what Aussie said. Thanks for the ideas guys!
Show us what you ended up making up or using please!
