what kind of wheels are these?
FiNorman
Lifetime Supporter
Orlando, FL
1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
The look like American Racing Atlas (Chrome)
American Racing-- Wheels Catalog
I do think they are close, but what I like about about those rims, if I were to describe them..... Six spokes that start from the center and deep inside the rim and taper to the out side of the rim with each spoke representing a triangle with the very tip of the triangle grabs onto the circumference of the rim. It almost looks like six sided star fish that's at the steering knuckle reaching to the outside of the rim.
If I can't id the exact model rims I might use the Atlas. Thx
Have you tried to call the place selling that vehicle and asking?
I thought about it, but in the later pics it looks like the restoration was done in a private garage then being sold by someone else.
I just sent an email to American racing to see if they could help.
Cool deal. I wish you luck, those are nice wheels!:chug:
I'd start with going to http://www.summitracing.com and doing a search for American Racing, chrome. They look much brighter than Polished Aluminum.
.... since the center caps rust and are often replaced, maybe just the center caps are American Racing, not the wheels. Just a thought
The deep dish version probably looks more like your pic. What elwood posted has much less offset/ backspacing
I think you and Mr. Blues are correct. They are Atlas, however it appears that the Atlas line has been discontinued. How do you order the deep dish version of any rim? I know it's the offset, but is it he lower the number the "deeper the dish"?
Backspace is the distance from the brake side of the rim to the bolting surface (where it hits the drum/rotor) - Offset is the distance that the bolting surface (where it hits the drum/rotor) varies from rim center.
So, a zero or negative offset will give you a deeper reverse on the rim - a lower backspace number will give you a deeper reverse. Just to make it harder to compare rims, width plays a big part. A 4" backspace on an 7" rim width would be a shallow reverse, but a 4" backspace on a 12" rim width would be a fairly deep reverse look.
About halfway through the attached is info on "Offset" that should make it clear. Backspace and Offset are basically two different ways of measuring the same thing just to keep us all confused.... :rolleyes:
