What Parts Cleaner Solvent?
  • Water Based
    Votes: 3 17.6%
  • Mineral Spirits
    Votes: 1 5.9%
  • Diesel Fuel
    Votes: 0 0.0%
  • Kerosene
    Votes: 3 17.6%
  • Comercial Solvent
    Votes: 6 35.3%
  • Gasoline!
    Votes: 1 5.9%
  • Other (Please specify)
    Votes: 3 17.6%
  • Total voters
    17
Featured
On my way out this morning to pick up some more kerosene for my parts cleaner (still cleaning the Transfer Case parts), I began to wonder what everyone else uses to clean their parts with?
I use kerosene as it works great and it seems to dry faster then diesel fuel. Mineral spirits works good but takes the damn paint off of too much that I clean.
What do you all use?
I just use my trusty pressure washer and some elbow grease.
Watch that Kerosene in the garage. that stuff is dangerous!
I go hard core. Straight gasoline baby!
At work we have a water based hot tank. It revolves and sprays with pretty good pressure. Whatever is left gets cleaned with a soaking in Optimizer(a fuel system cleaner) and sprayed with brake and parts cleaner. If that doesn't remove something, it was probably cast into the part.
Man - I wish I had a pressure washer sometimes! :)
As for the kerosene, you make a valid point. It is flammable so if you are using it in a tank of some sorts, make sure it has some sort of fire suppression system (my washer has an automatic system to close the lid). And if your like CW and crazy enough to use gasoline... Well, same thing. :D
I use the shop parts washer and It has Ozzyjuce in it and it works really well. I also use a product from ZEP called ID Red better than brake clean with no residue left over.
Whaaaa??? Crazy? Safety is wayyyyyy over rated. LIVE LARGE!!!
CJ, I bought my little pressure washer (1200 psi) many years ago at a garage sale for $25. Its been a real good investment!
I use mineral spirits- if it should ignite, it will do so much slower and give me enough time to get away and close the lid on the parts washer.
I'm going to tick a few of you off, but cleaning with gasoline is the worst thing one could ever do. You have no idea how quickly it will flash or even explode in a closed area. Static sparks will set it off. I say this because a friend of mine is dead as a result of using gasoline to clean engine parts. He simply stepped on the shallow pan on the floor, the gas splashed on him and he was consumed in seconds- never found out what caused the ignition. As a member of the Vol Fire Dept- try going on a call and hear the terrifying screams of some one who has met with gasoline- and there is nothing you can do- death would be a comfort for many of them. If you survive- you may wish you hadn't.
The morgue is full of "I've done this all my life" scenarios.
Take a minute and see what can happen- if your one of the lucky ones;
15-Burn Victims pictures and videos on Webshots
This may be off topic, but for sakes alive, I deem it extremely important.
Falun Dafa Clearwisdom.net
"He said that he was burned rinsing machine parts with gasoline while he was repairing a machine for his work unit. A colleague nearby was using an open flame which ignited the gasoline vapor in the area and then on his skin. I asked, "How come the flame burned you so badly?" He said, "Because I was using gasoline." When I inquired further, he told me that it had been ten days since he was burned.
I asked him, "How long were you actually in contact with the gasoline flame?" He answered, "Only two to three seconds." I asked, "You were burned so severely after only two to three seconds?" He affirmed, "Only two to three seconds!"
1139669079042639574uaGLpi
I use this mix I've used for awhile on various hobbies and stuff:
"Make you own cleaner easily and affordably by mixing two parts denatured alcohol with one part Simple Green. Store the cleaner inside a pump spray bottle, and top off the brew with a capful of WD-40. Be sure to shake the bottle before every application because the solvents separate over time."
Spray it on let it sit then hose it off, it's a great dirt and degreaser, scrub at the tough areas.
McConell's reply is true, sad but true indeed. To add to that info on flammability.
Gasoline and diesel are considered carcinogenic (causes cancer) in both vapor and liquid form. They are also linked to causing Leukemia, reproductive issues, and fetal development. The fetal development is passed along from the parents not just from direct exposure.
Mineral Spirits albeit still very flammable it is not carcinogenic.
I am not trying to judge anybody, I used gasoline when I was younger and didn't know any better. But knowing what I know now I just can't use it any longer and felt obligated to share the info.
Ok, I just came across this article on yahoo. I had to share. Here. This is the only place to put it. Just trust me and read it. You only have to read part of it. You will know when to quit when you get there.
Five surprising uses for ketchup
By Brian Clark Howard
Posted Wed Apr 29, 2009 5:37am PDT
Related topics: Food and Drink, Cleaning, Reusing stuff
More from The Daily Green News blog
12 votes
Buzz up!
(Photo: Craig Veltri / iStockPhoto)
Whether you enjoy ketchup with fries or -- like some Americans -- a few fries with a boatload of ketchup, there's no denying the ubiquity and popularity of the distinctive red condiment. Ketchup has been satirized, politicized (W Ketchup anyone?) and considered for reclassification as a vegetable. Many folks can't even agree how it should be spelled (catsup or catchup perhaps?).
We're guessing we're not the only ones who squirrel away unused packets of ketchup in desks and cabinets after a quick meal on the go. (Or who have aging, half-empty bottles of the stuff crammed in the back of the fridge.) And since we hate to waste things here at The Daily Green, we got to thinking about ways to creatively reuse extra ketchup -- we mean besides the obvious choices of making recession ketchup "pizza" or "spaghetti." Shudder…...
By the way, wonder what's in ketchup? Typically tomato concentrate (duh), the ubiquitous corn syrup or another sweetener, vinegar, salt, spice and herb extracts (including celery), spice and garlic powder. Some brands also include allspice, cloves, cinnamon, onion and other vegetables.
While none of us should be eating too much salt or corn syrup, it's hard to argue with the fact that the ingredients list is decidedly non-toxic, especially when you compare it to the chemical-laded conventional cleaning products and shampoos that it can replace.
So check out these great alternative uses for ketchup, which will save you money and time:
Shine your copper
Whether you have copper-bottomed cooking pans, architectural detailing, or shiny knick-knacks, forget mucking about with costly and potentially toxic metal polish pastes. Why not use some of those old ketchup packets stashed away in your kitchen drawers?
Here's a very simple recipe from Michael de Jong, TDG's Zen Cleaner and author of the Clean series of simple living books:
Massage ketchup over the copper and watch it dissolve the tarnish away (thanks to the acid). In the event that you have stubborn spots, add a pinch of table salt while you polish.
Get those auto parts gleaming
According to The Cymbal Book by Hugo Pinksterboer, some folks have seen decent results getting their cars to shine by rubbing with ketchup. The book notes that the condiment does a good job cutting tarnish, but not so well in removing dirt. Sounds like you may need a multi-step process, with some soap and water as well.
Give it a try and let us know if it works for you.
Fight Skunk Odors
If you've lived in a rural or even suburban part of North America, chances are you may have had a run-in with a skunk one night or evening. Or perhaps your dog has. Although some experts have cautioned that the technique may not actually work well (beyond a masking sensation), many people still swear by tomato juice as a way to remove potent skunk odor. Michael de Jong points out that in the event you don't have any tomato juice on hand you can try using plain ketchup instead.
Get back prettier hair from chlorine damage
According to de Jong, ketchup can also be used to correct limey-hair-highlights-gone-green, which can sometimes occur from exposure to chlorine found in swimming pools (another good reason to check out natural pools as a refreshing alternative).
How? Restore your normal hair color -- or at least the one you paid dearly for -- by applying full strength ketchup to your hair. Smoosh it in, let it linger for about 20 minutes and then wash it out thoroughly.
Soothe wounds
Unused ketchup packets pile up across America by the millions, as hurried diners and service staff often grab huge handfuls, only to end up using a few. Lisa posted over on Seacoast Online that she freezes leftover ketchup and soy sauce packets to use on her children's "small booboos and bumps." She claims, "The kids LOVE them." Apparently even the mere appearance of the packets often makes their hurts go away.
Want to make your own ketchup? Check out this link for a unique cranberry ketchup recipe, or get zillions of other ketchup ideas from Delish. Get more green cleaning recipes from Quick and Simple.
Five surprising uses for ketchup | Yahoo! Green
:) Maybe someone should try this :)
Stuff with heavy grime gets taken to work and steam cleaned then washed in the solvent tank. Light dirt gets Castrol "Super Clean" then the parts smell great too.
I use kerosene as well, this may be off course but there is an article in the New York times that kerosene is also the solution for the gasoline problem, there should be kerosene run vehicles. Interesting huh.
While Kerosine is not supposed to be carcinogenic, and should not have the same fetus/ birth defect dangers as gasoline and diesel fuel, that statement is made with a caveat that those assumptions are based on incomplete info so far.
Kerosine still has its fair share of health concerns, especially if inhaled.
It does have affects on the human body in both short and long term exposure. Such as; irritability, restlessness, drowsiness, dermatitis, convulsions, ataxia, coma, and death.
After doing some of the research I think pretty much any petroleum based product is going to be bad for us in one way or another. So no matter what we use please be careful, and take proper safety precautions.
