    To dismiss this notice
    click the top right X.
What Transmission will replace BW-T4
RedDog
Canton, TX
1982 CJ7 - Stock until my pocket gets bigger!
258 I6, T4 Trans, D300 Transfer, AMC 20, Dana 30.
My Tranny bit the dust last night.... lost 3rd gear with a load pop and bang... thought I lost a drive shaft, pulled over and everything was intac but there is a lot of grinding and rattling coming from the Transmission .
so i leamped it home with no 3rd gear....
I have an 82, AMC 258 i6 / 4.2l w/ the borg-warner T-4
I have a buddy that can rebuild it for 375 + parts, but I am leaning toward getting a better stronger Transmission , will the T-176 bolt right up or will I have to change bell housing..etc.
what about the T-5 , upgrade to 5sp? is it just as weak as the T-4 ?
any guidence would be greatly apprecaited
Thanks,
Ok, I am on the hunt for T-176
Anybody in Texas got an extra one laying around?
I concur with 1986CJ7. I have done quite a bit of research on the matter since I have a T-5 where the 2nd gear sync is going out. The T-4 and T-5 are supposedly the worst transmissions ever put in Jeeps. You can get T-4 's and T-5 's up here in Washington on CL for as low as $100 in operating condition since people do engine swaps and just decide to replace them because of their rep. With that being said, I have decided to stick with my T-5 since I can replace it for dirt cheap. Hell it lasted for 29 years so it can't be so bad. That is the same reason I am sticking with my 258I6 too.
$40.00
  20.0%
