What's with this?
What's with this?
gitz676
Millet Alberta Canada
1982 CJ5, 360 AMC, AMC 20 diff, 176 trans, dana 300 TC, dana 30 front diff.
That looks like it would be the mounting hole for the alternator, look at the front of the passenger side head and you will see the hole. It is not supposed to go all the way through but maybe it was a bad from Toledo or the bolt broke and some one drilled it out a bit too far
In my opinion the J B weld will melt and puddle up on the floor. I would have to suggest pulling the head and re drill and tap for a pipe plug rather than a bolt. If you do use a bolt it will have to have a head on it to actually seal and stay put. For a temporary fix you can use sheet rock mud. It is gypsum based and will hold up to the heat until it cracks out, i have known several guys that passed inspection with this trick.
Any way you look at it to fix it for permanent it will require pulling the head. If you had been lucky you would have put that head on the other side and mounted the alternator to it and never known the hole existed.:D
That's exactly what it was. I had a 50-50 chance of not having the problem. I cut a small access hole in the firewall and screwed in a cap screw with lock-tite. I have so many patches in the floor of the tub, another one did not matter. LOL
