Wheel bolt patterns
frhrwa
- Media
- 6
- 1984 CJ-7 (just bought it, so I have to do some work and see what it has in it.. other than 4.2L Auto.. 4" lift, 33" tires... my '75 had a 304 2" Burbank supspension, warn winch, full cage, all the goodies, the '79 had a 401 turbo charged hi-po with t98 or 18, which ever one had the granny low first gear (never can remember which).. had all the items needed to 4wheel, none of the show and go poopie.. I don't believe "chrome will get you home"! I'm also not one to go out to see if I can tear up my jeep, I go where I must, usually with a group that I hung with.. Used to be part owner in Diablo Off Road Center in Concord California.. Jack Essex owned Diablo 4WD, George Clause was Mr. Base CAmp, and mine was "Sounds Etc" all under one big roof "the Diablo Off Road Center"..
I measured my '84 CJ7 bolt pattern, came up with 5 5 1/4, seems to me every jeep I've owned (which were older) were 5 5 1/2 ? had a friend measure, came up with the same 5 5 1/4 what gives? is there anyway the axles got swapped for some weird abnormal pattern? or am I using a Chinese measuring tape? I need to put some stock 14 or 15" wheels with the smallest tires I can find, on my jeep in order to get it into the enclosed trailer to haul north.. I'm 6" too tall with my 33's on 15's.. so, even thought about putting down another sheet of plywood and winching the jeep on with just bare wheels.. and cross strapping ..? HELP..
