wheel spacers
jeepboy45
Old Time Jeeper
- Altamonte Springs, Florida
- 1979 CJ-7, Newly rebuilt AMC 360!, fully rebuilt GM TH400, Quadra-trac TC w/Milemarker 2x4 conversion, AMC mod 20 rear w/1 piece Moser axleshafts, mod 30 front w/tie rod flip and castor correction shims, 4 in lift, Centech complete wiring harness, dual electric fans on 3 core aluminum radiator, tilt steering wheel, 20 gal poly gas tank, new J20 steering box, MSD 6A ignition combined with TeamRush distributor mods
I have a question....
I have a 79 CJ7 with the narrower track and had a wild hair thinking about using wheel spacers
Does using wheel spacers to give a wider stance put added pressure on wheel bearings?
Today a guy at a Jeep parts store just told me they do. I can "see" that putting the wheel further from the bearing would be like adding leverage to the stress mounting point......
But on the other hand, by bolting the wheel to the spacer which is also bolted ( or sandwiched ) between the wheel and spindle....isnt the load on the bearings still the same??
(waiting for BusaDave9, CJ, Sasquach, Purple 77CJ7, or OldDog to lend some tech info )
