wheel spacers
wheel spacers
jeepboy45
Old Time Jeeper
Altamonte Springs, Florida
1979 CJ-7, Newly rebuilt AMC 360!, fully rebuilt GM TH400, Quadra-trac TC w/Milemarker 2x4 conversion, AMC mod 20 rear w/1 piece Moser axleshafts, mod 30 front w/tie rod flip and castor correction shims, 4 in lift, Centech complete wiring harness, dual electric fans on 3 core aluminum radiator, tilt steering wheel, 20 gal poly gas tank, new J20 steering box, MSD 6A ignition combined with TeamRush distributor mods
I have a question....
I have a 79 CJ7 with the narrower track and had a wild hair thinking about using wheel spacers
Does using wheel spacers to give a wider stance put added pressure on wheel bearings?
Today a guy at a Jeep parts store just told me they do. I can "see" that putting the wheel further from the bearing would be like adding leverage to the stress mounting point......
But on the other hand, by bolting the wheel to the spacer which is also bolted ( or sandwiched ) between the wheel and spindle....isnt the load on the bearings still the same??
(waiting for BusaDave9, CJ, Sasquach, Purple 77CJ7, or OldDog to lend some tech info )
Yes it does put added presure on the bearing. You might need to change them a little more offton but not that big a deal.
I'm not a fan of them but if you buy high quality ones and keep the nuts tight you should be ok.
Old Dog is right, as usual :notworthy:. I've ran wheel spacers on my '01 XJ for 4 years now and haven't had any issues. The biggest thing, like Old Dog said is to purchase high quality (spidertrax), hub centered spacers. Not some POS thing of ebay someone made in thier garage.
I run Spidertrax spacers on my rig. I do have to check the wheel bearings for tightness more often during the season. Also have to keep checking wheel bolts that bolt the spacers on often,too. I have had no issues in 6 years. With the narrow track axles I think they are worth it.
The old school thought is that they are bad...With modern engineering and a high quality manufacturer, I see no reason to shy away from them. They will increase your scrub radius a tpouch and you may see a little more tire wear (from cornering) but it should be very minor. If you can live with that, I say go for it.
