Which fuel sender is best?
Rexx66
Evansville, IN
1979 Jeep CJ-5
Straight 6, 3 speed
Needing a new fuel sender/sensor since finding out the current one isn't working properly to a new gas gauge(keeps showing a constant full tank)
So any ideas on which one is best, and also how do I know which tank I have on my 79 CJ5 ? Saw on jeep4x4world that there's a 15 and a 20 something gallon tank.
And finally is it possible to make the swap without dropping the tank? Jeep appears to have a body lift so I can see it but looks to be pretty tight. Thanks!
Tell us more about the new gauge. there are about 10 different resistance ratios for aftermarket gauges and there is a good possibility the one you have does not match the jeep sending unit.:cool:
you are going to love dropping the tank, something everybody should have to do once. Careful with the hoses and you may be able to reuse them. I would suggest you at least locate some new ones before dropping the tank.:D
If you don't want to drop the tank, you can cut a hole in the floor and put an axcess door there for the future. I don't know why amc didn't do that. I have one in mine for that reason. So much easier.;)
can we see pictures of yours??
Any one have a list of the potential / correct resistance values?
Years ago I put an IronMan 21 gallon tank in my '81 CJ, and it never has read quite right since then. I recently replaced the sender with a 20-gallon one, but it still reads full a long time, and shows empty too soon.
Better than the opposite I suppose.
Any one have a list of the potential / correct resistance values?.
73 empty 10 full
For anyone having problems with the plastic float, I hear that ford has a brass one that fits. part # COAZ-9202-B.
I need to do this but haven't yet.
