Whiskey Tango Foxtrot
007
Crazy Sr. Respected Jeeper
- Media
- 5
- Solutions
- 1
- Reno, NV
- 1977 CJ-7 Renegade (Daisy Jane), Levis trim, 304, TH400, BW1339 (MM), D30/Auburn Max, AMC20/Detroit/G2's, 4.88's, 33" BFG MT KM2's, Edelbrock Performer intake, Holley Sniper 4bbl EFI, MSD6, MSD ProBillet distributor, OME shocks, 4" ProComp lift.
So I started my Jeep for the first time with the clear fuel filter installed. I had made NO other changes. NONE.
It barely ran. Was blowing black smoke and puking fuel out the top of the carb and making pools on the intake.
I had to set the fuel pressure regulator DOWN from 6psi to 3psi to make it run even half way decent. I also noticed that while it was running the clear fuel filter was in fact clear I couldn't see any gas in it if you can in the picture below.
Should I have put the fuel gauge in front of the filter meaning between the filter in the carburetor? What in the world else could be going on?
