Frame Widened Frame
Frame Widened Frame
1badcj8
Silver City New Mexico
1982 1-Ton CJ-8 Scrambler, kinda not stock any more...
1982 Jeep Scrambler... Also not stock any more.
I’ve heard that’s a pretty common thing with CJs.
I think I'm going to try a Chain come-along with some soft shackles and pull into place and perhaps weld in a brace made with pads/feet on it to weld to the frame right behind my skid so it wont be in the way???
I’ve heard of using that and some type of ratchet straps. I’ve also heard of people having to spread them back out, opposite of your problem.
Yeah I've Heard things like that as well. Has anyone here done it?
I did a search and didn’t find much of anything. That doesn’t mean it was a good search. @CJ are there any good threads on warped frames ? Thanks
Yep, I squeezed a frame a very long time ago.
Ratchet straps and a few wide torched t relax the spring steel. The bad thing is you loose steel temporing.
Your frame will be permanently weekend.
What about a long piece of threaded rod through a drilled hole in each frame rail, with a backing plate and a nut. 5/8” dia might be enough. I imagine with the cross pan removed, you could go across tight to the output at the rear of the Transfer Case .
My son's project has the opposite problem, its 3/8" narrower than called for through the middle, which puts the front eyes of the rear springs at 35 5/8" C-C instead of 36", and the rear eyes of the front springs at 26 5/8" instead of 27"
$45.00
  22.5%
