Will i have to change my drive lines
All transplants I've done involved lengthening and shortening the drive shafts.
Most important is the they don't come off the splines or bottom out and wreck the Transfer Case . :(
Collapse the springs and measure the distance. Extend the springs and measure. I use a High lift for both measurements.
Then check against your current drive shafts. Local driveshaft shops can cut and weld.
I highly recommend Tom Wood's. Great service and they know Jeeps. :D
