Wiper Wiring - 80 Cj5
Allen9878
Central Wisconsin
1980 Jeep Cj5 Renegade
I258 1987 Engine
Aisin Warner Ax15 Transmission
Dana 300 Transfer Case
I have a 1980 CJ5 and am currently starting to wire up the wipers that weren't wired at purchase. I have a mid 80's tilt chevy column and a stock 1980 cj wiper motor.
I believe I have found the diagram for the wires on the column itself but was hoping someone could help me with what wires are what on the motor? The colors are White, purple, yellow, green.
I would look in the manual but I don't currently have it. Any Help is appreciated
The column diagram showed this:
B(white) washer switch
C(gray) wiper high
D(green) wiper motor feed
E(purple) wiper low
F(dynamic feed) - B +
If anyone knows differently or any info at all, its appreciated
Try this diagrams worked for my 2 speed wipers and washer motor.Your plugs might not be the same but you can individually wire them with a 2 speed switch and it will work.Mike:chug:
