Wiring Push Buttom Start Gone Wrong
dazedandconfused
- Yankton, South Dakota
- 1981 Jeep CJ7 258 I6, Motorcraft 2100 carb
Hello, I’m currently in the process of building/ restoring a ‘81 CJ7 . I’m in college for autobody repair so I don’t have a whole bunch of money floating around. I took my CJ on a Sunday drive and stopped and got some groceries. When I came out, it would not start from the key, so I jumped the solenoid with some pliers, got home and it wouldn’t shut off from the key. I replaced the ignition switch and now it will shut off from the key but still will not start. I’ve come to the decision to install a push button start. I installed a momentary push button switch using 10 gauge wire. I ran one wire to the positive battery post and the other wire to the “S” terminal on the new solenoid. I turn the key to the run position and all I get is cricketts. I plan to rewire the Jeep and rebuild the steering column once summer hits and I can work more. Any advice or help would be greatly appreciated.
Thanks!
Sam
Thanks!
Sam
